I’ve owned two (2) - 2006 Mazda 6S 3.0 V6 and have experienced the same issue with both.
I’ve seen a number of other similar reports on the forum, but I didn’t see any dedicated threads and I’m curious to find out how many other people have encountered this problem.
When I’m running low on gas and get down to around ¼ tank of gas, making a turn or accelerating quickly will cause fuel-cut out and bucking/stuttering. Basically anytime I’m doing something that can cause the gas to slosh around in the tank I run the risk of losing power.
I experimented in an empty parking lot and am able to get the car to stall completely just by driving it in a tight circle at 5-10 MPH. As soon as I fill the tank back up, I can drive in circles all day long with no problems.
Here’s where it gets interesting…
The first Mazda 6 I bought had this issue when I bought it, but I didn’t realize for almost a month after I purchased it because I never let the gas get down far enough.
My second Mazda 6 did not have this problem until about a month ago – The gas light came on while I was driving to work and I was running late so I wasn’t able to fill up until after work (10-12 miles after the light came on) As I was approaching the gas station after work, my car started bucking/stuttering when I was about two blocks away. I made it to the gas station and never actually totally ran out of gas, but ever since the incident I’ve had issues with loss of power and bucking anytime my gas level hits ¼ tank.
1) How many of you have run into this problem?
2) Does anyone know exactly what’s causing the problem and if it can be fixed without replacing the fuel pump?
3) Do you really need that special tool that costs $200 to remove the fuel pump?
